April 13, 2023 at 7:32 am
Solution
ParticipantIn the Surface of Revolution creation, the 3D Domain choice doesn’t cut the surface directly. For example, a cylinder method will create a whole cylinder even if a Domain is chosen which should show one specific angle of the cylinder. Choosing a color in the Surface of Revolution Color tab, fit the Domain choice but the whole surface is displayed all the same. This Solution shows a workaround to display a Surface of Revolution in the wanted Domain only. Please, see the attached document.
1. 2058160.pdf
- Skewness in ANSYS Meshing
