April 13, 2023 at 7:33 am
Solution
ParticipantPlease see attached video. It shows how to use ‘Blend’ tool to create surfaces from curves and then ‘Fill’ tool to create solid. Keywords: blend, curves
1. 2046091.zip
- Skewness in ANSYS Meshing
