Tagged: 17.2, Create Geometry, designmodeler, fluid-dynamics, geometry, Other
June 5, 2023 at 7:05 am
FAQParticipantWhen you have a surface body that encloses space, you can create a solid body with that surface body as the surface of the solid. Procedure: 1. Open the Create dropdown menu and select Body Operation. 2. Select Sew as the Type. 3. Click on Bodies and select your surface body. 4. Select Yes on Create Solids? 5. Click Generate to render the solid.
- Skewness in ANSYS Meshing
