June 6, 2022 at 10:32 am
FAQParticipantThe most straightforward way to do this is to generate matching face meshes on the periodic face pairs. As for the setup of the periodic boundary type in Fluent, you can do this two steps:
1) Make sure to set properly the origin and orientation of the cell zone under Cell Zone Conditions panel
2) You can set up the periodicity manually with Text User Interface command: /mesh/modify-zones/make-periodic and follow the arguments needed to complete the command, accordingly.
An example of this command is: /mesh/modify-zones/make-periodic periodic_a periodic_b yes yes
- ANSYS Fluent: Watertight Geometry Meshing Workflow
- Tip on exporting geometry in Parasolid, STEP format from DesignModeler
- Create Sections in Meshing
- How to reverse surface normal in SpaceClaim?
- ANSYS ICEM CFD: Basic Blocking
- How to Change the Direction of the Normal Vector of the Internal Face?
- ANSYS Workbench: Decomposition and Hex Meshing – Part I
- Fluent: Watertight Geometry Meshing Workflow
- How to Fix the Error: “Mesh Exporter does not Support Overlapping Geometry in Named Selections”?
- How can I create a 2D section from a 3D model in SpaceClaim ?
