April 13, 2023 at 7:33 am
SolutionParticipantTo create a point at the mass center of a solid, we follow the steps below. A demo is in attachment. 1) Select the body of interest. 2) Click on the Origin button in the Create section of the Design ribbon in order to define a new coordinate system located at the mass center of the solid. 3) Select the newly created origin and click on the Point button in the Create section of the Design ribbon.
1. 2041180.zip
- Skewness in ANSYS Meshing
