March 17, 2023 at 8:58 am
FAQParticipantTo create a pattern, we can use the pattern tools (one- or two-dimension linear pattern…). We can also use the Move tool: 1)Click Move in the Edit section of the Design ribbon. 2)Check the Create patterns option in the Options -Move panel. 3)Select a protrusion, depression, sketch, points, axes, planes, origins, or 3D curves to be the first member of the pattern. 4)Drag a move handle to copy the first pattern member to the location of the last member of the linear pattern. 5)Type a new value for the pattern count. Press Tab to change the distance or spacing.
- Skewness in ANSYS Meshing
