March 17, 2023 at 8:58 am
FAQParticipantTo create a helical revolve: 1)Select the Pull tool. 2)Select the face or edge you want to revolve. 3)Alt+select a line or an axis to revolve about. 4)Click the Revolve helix option in the Options panel and enter dimensions for the helix.
- Skewness in ANSYS Meshing
