March 17, 2023 at 8:58 am
FAQParticipantTo create a circular pattern 1) Select the geometry you want to pattern 2) Click the Circular Pattern tool in the Create group of the Design tab 3) Select the axis of rotation and provide the pattern parameter in the option panel.
- Skewness in ANSYS Meshing
