March 17, 2023 at 8:58 am
FAQ
ParticipantIn CFD-Post, it is not possible to choose the option “Equally Spaced” to create Vectors when a 3D Domain is selected. A workaround would consist in creating Streamlines from any Inlet or any Section Plane, with the option Sampling=”Equally Spaced”, to be able to create Vectors on them. The option Reduction Factor higher than one, or adjusting Max Number of Points, allows to get a good display.
- Skewness in ANSYS Meshing
