March 17, 2023 at 8:58 am
FAQParticipantThis is not possible directly, but you can make a component/assembly performing the following steps: 1) Right-click the inserted, dependent component in the Structure tree 2) Hover over the Source option and select Make Independent from the context menu 3) You can hold the Shift key to select multiple components and make them all independent at once.
- Skewness in ANSYS Meshing
