Tagged: 18, fluent, fluid-dynamics, General, General - FLUENT
May 15, 2023 at 8:32 am
SolutionParticipantIt is a good practice to mesh only half of a symmetrical geometry in order to reduce the model size and get faster time to solution. When the boundary conditions are not symmetrical anymore (like side wind for external aero calculation) the user needs to run on the full geometry. You will find in the document attached below a solution to get the complete model from a symmetrical model in Fluent Solver.
1. 2051486.pdf
- Skewness in ANSYS Meshing
