April 13, 2023 at 7:33 am
Solution
ParticipantTo convert a cylinder into a box with rounded corners, select the axis of cylinder and activate Pull tool. Pulling the axis will get converted into a box with rounded corners. A demo is in attachment.
1. 2050925.zip
- Skewness in ANSYS Meshing
- ANSYS Fluent: Introduction to the GEKO Turbulence Model Part I
