Tagged: 18, Electromagnetics & Electronics, hfss, modeler, Other
May 25, 2023 at 7:30 am
SolutionParticipantyou have to import the model, place it in the layout and then select the pins of the model, some layout edges and connect them under the draw menu, see illustrated attachment
1. draw%20connection.mp4
2. solution%202048583%20how%20to%20connect%20external%20Spar%20set%20to%203D%20Layout%20geometry.pdf
- I got “I/O error when reading design” error message when opening an AEDT project with HFSS 3D Layout designs after a system crash. How should I proceed to recover my project?
- How to Export S-Parameters from HFSS 3D Layout/HFSS 3D Designs ?
- ANSYS HFSS: Creating 3D Components
- Error: Extracta view creation failed; extracta run failed: Create process failed with error 2: Could not find application extracta.exe.
- How to export a design from HFSS 3D Layout to HFSS 3D Classic?
- How to Set “Non-Model” Property to an Object in 3D Layout
- ANSYS HFSS: 3D Layout Cut Out Sub-design – Simulation and Post Processing
- ANSYS HFSS: 3D Layout Model from a Cadence Board File
- How to Create Bondwires in 3D Layout ?
