Tagged: 17.2, contact, mechanical, structural-and-thermal, structural-mechanics
January 25, 2023 at 7:34 am
FAQParticipantBeam and solid cannot have shared topology. However, one may use node merge in Mechanical which will join the two bodies like a hinge, i.e., rotational degree is not connected, and moment is not passed. Also one may use a bonded contact.
