Tagged: 18.1, BCs & Interfaces, fluent, fluid-dynamics, General, materials, rotating-machinery
June 5, 2023 at 7:06 am
FAQParticipantFor this you do not need to have any moving mesh. Just define the mesh around the blade as moving as rigid body, forces computed via 6dof on the blade.
- Skewness in ANSYS Meshing
