June 6, 2022 at 10:32 am
FAQParticipantTo perform faster mesh independence studies in CFX, a 3D mesh can be simplified to a quasi-2D mesh by making it a 1-element thick sweep mesh. When performing this, the user should focus on node count. However, when comparing the mesh statistics between the 3D and quasi-2D meshes, the focus should be limited to skewness and orthogonal quality. This is because these two metrics are not influenced by the thickness of the sweep mesh while other metrics, like element quality and aspect ratio, are affected.
- ANSYS Fluent: Watertight Geometry Meshing Workflow
- Tip on exporting geometry in Parasolid, STEP format from DesignModeler
- Create Sections in Meshing
- How to reverse surface normal in SpaceClaim?
- ANSYS ICEM CFD: Basic Blocking
- How to Change the Direction of the Normal Vector of the Internal Face?
- ANSYS Workbench: Decomposition and Hex Meshing – Part I
- Fluent: Watertight Geometry Meshing Workflow
- How to Fix the Error: “Mesh Exporter does not Support Overlapping Geometry in Named Selections”?
- How can I create a 2D section from a 3D model in SpaceClaim ?
