June 6, 2022 at 8:32 am
FAQParticipantAfter the adjoint solution, the Design Tool feature allows to set the bounding box using two methods: Cartesian & Cylindrical as shown in the attached image The bounding box method should be chosen according to geometry shape. For example, when optimising flow over rectangular surfaces, a cartesian box shape is more suitable, while for turbo applications (ie: optimizing blade geometry ), a cylindrical shape will be more suitable.
- Skewness in ANSYS Meshing
