How to check the amount of memory used during a simulation? What is the TUI command for “Memory Usage”?
April 5, 2023 at 2:32 pm
FAQ
ParticipantIn the graphical user interface (GUI) you can check the amount of memory, currently used, in the Ribbon on the tab “Parallel” under “System” with “Memory Usage”. In the text user interface (TUI) the corresponding command can be found under “report/system”. /report/system/proc-stats This TUI command can be added in a journal or added as a “Calculation Activity”. If you use this TUI command and record a transcript, you can monitor possible changes in memory being used.
- Skewness in ANSYS Meshing
- ANSYS Fluent: Introduction to the GEKO Turbulence Model Part I
