March 17, 2023 at 1:10 pm
SolutionParticipantTangencies between surfaces or sharp angles between surfaces can lead to bad cells in the mesh. Such issues are very common in Fluids domains due for example to contact between rounded solids. “Sharp Edges” detection tool in SpaceClaim can be used to flag those places so they can be fixed in the CAD. Please look at the PDF attached for more information.
1. 2063824.pdf
- Skewness in ANSYS Meshing
