General
General
How to check for the amount of memory (RAM) consumed by a Fluent run
    • FAQFAQ
      Participant
      You should be able to use the following command in your Fluent console to check for memory consumption. (proc-stats) Prints ANSYS Fluent process information. This is used to report the memory usage of each of the ANSYS Fluent processes. Please note that brackets are part of the command. Keywords: RAM, Fluent, memory
