Tagged: 18, fluid-dynamics, General, workbench platform
June 5, 2023 at 7:05 am
FAQParticipantRight-click on the Workbench icon, select Properties. Under the “Shortcut” tab, you will find the “Start in” area. default: %HOMEDRIVE%%HOMEPATH% You can change this to a desired driver/path.
- Skewness in ANSYS Meshing
