Tagged: 2019 R3, BladeEditor, BladeModeler, fluid-dynamics, turbogrid
April 13, 2023 at 7:32 am
SolutionParticipantFor cut-off trailing edges in TurboGrid, a certain mesh topology is used that resolves the corners of the cut-off. This mesh resolution is carried from the trailing edge to the outlet. It may be desired to have TurboGrid apply a different mesh topology to eliminate this mesh refinement. Assuming the blade was defined in BladeEditor, a method for modifying the blade trailing edge is presented that will cause TurboGrid to select an alternate mesh topology. Please refer to the attached file for details.
1. 2061768.pdf
- Skewness in ANSYS Meshing
