June 6, 2022 at 10:32 am
FAQParticipantThis is the procedure for changing the height of the prism mesh for each zone.
1.Open Mesh/Prisms…
2.Select an arbitrary wall from Boundary Zones and click Apply in Zone Specific Growth
3.Select any wall other than the one selected in step 2, and click Apply in Zone Specific Growth
4.Repeat step 2 as necessary
5.Click on List in Zone Specific Growth to see if the settings displayed in the TUI are correct
6.Select all the walls from the Boundary Zone and click Apply at the bottom of the panel
- Create Sections in Meshing
- Tip on exporting geometry in Parasolid, STEP format from DesignModeler
- How to reverse surface normal in SpaceClaim?
- How to Change the Direction of the Normal Vector of the Internal Face?
- ANSYS Fluent: Watertight Geometry Meshing Workflow
- ANSYS Workbench: Decomposition and Hex Meshing – Part I
- ANSYS ICEM CFD: Basic Blocking
- How can I create a 2D section from a 3D model in SpaceClaim ?
- What is the difference between patch dependent meshing and patch independent meshing?
- Fluent: Watertight Geometry Meshing Workflow
