June 6, 2022 at 10:32 am
FAQParticipantTo increase the degrees of freedom in post-processing, you may want to reverse the direction of the normal vector. A feature called Flip Normals can be used in Fluent Meshing. In FLUENT, it is possible to align normal vectors of internal faces, such as the interior, to a certain direction as required. However, we cannot decide which direction the normal vector can take. In that case, we will use Fluent Meshing’s Flip Normals function.
First, confirm the direction of the normal vector.
Next, go to the Boundary > Manage… and enter the following settings.
Options: select Flip Normals Face Zones: select the applicable internal face
Click Apply and check if the direction of the normal vector has reversed.
If there is no problem, save the mesh file. If the boundary conditions etc. have already been set, copy the settings.
- Create Sections in Meshing
- Tip on exporting geometry in Parasolid, STEP format from DesignModeler
- How to reverse surface normal in SpaceClaim?
- How to Change the Direction of the Normal Vector of the Internal Face?
- ANSYS Fluent: Watertight Geometry Meshing Workflow
- ANSYS Workbench: Decomposition and Hex Meshing – Part I
- ANSYS ICEM CFD: Basic Blocking
- How can I create a 2D section from a 3D model in SpaceClaim ?
- What is the difference between patch dependent meshing and patch independent meshing?
- How do you turn a rectangular surface mesh into a triangular surface mesh?
