Tagged: 19, General, mechanical, static, structural-and-thermal, structural-mechanics
April 13, 2023 at 7:32 am
SolutionParticipantPlease refer to the attachments to access the Solution.
1. 2054250.zip
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
