April 13, 2023 at 7:32 am
Solution
ParticipantPlease refer the attachments to access the solution.
1. 2053109.pdf
2. 2053109.zip
- ANSYS Mechanical: Node Merge
- ANSYS Mechanical: Node Move
- How to use ANSYS Workbench Meshing Virtual Topology
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How to use ANSYS Workbench for Merging Mesh Nodes
- How can you identify the element types used by Mechanical?
