Tagged: 19.2, cfd-post, fluid-dynamics, General, swirl velocity, Turbo Post-processing
April 5, 2023 at 2:32 pm
FAQParticipantIn CFD-Post, go to the Turbo tab and click on Calculate Velocity Components. This will create a variable called Velocity Circumferential which is the swirl velocity.
- Skewness in ANSYS Meshing
