Tagged: 17.2, fluent, fluent-post-processing, fluid-dynamics, post-processing
March 17, 2023 at 1:10 pm
SolutionParticipantSummary: Simply define a new Custom Field Function by multiplying the Effective Viscosity from the Turbulece group with the Strain Rate from the Derivatives group. For more details refer to the attached document.
1. 2045478.pdf
- Skewness in ANSYS Meshing
