August 25, 2023 at 12:15 pm
SolutionParticipantIt can be needed to post-process the radial, axial and circumferential velocity components for non-turbomachinery cases. It can be done through the Turbo tab. Please, see the attached document for more details
1. 2049268.pdf
- Skewness in ANSYS Meshing
