General
General
How to calculate swirl in Fluent?
    • FAQFAQ
      Participant
      You can do this through a surface integral as follows: The swirl number is defined as the radius-weighted ratio of axial flux of angular momentum to the axial flux of axial momentum. SWIRL_NUMBER = FLOWRATE(radius*tangential-velocity) / FLOWRATE(radius*axial-velocity) You can use custom field functions to obtain radius*tangential-velocity and radius*axial-velocity. Some users use a reference radius in the denominator such that: Denominator = radius_ref*FLOWRATE(axial-velocity)
