June 5, 2023 at 7:05 am
FAQParticipant1. Create the Expression : NOX ppm dry exp = NO.Mole Fraction* 10^6 /(1 – H2O.Mole Fraction) 2. Create the Variable, NOX ppm dry and set it equal to the expression: NOX ppm dry exp
- Skewness in ANSYS Meshing
