April 5, 2023 at 2:33 pm
FAQParticipantGiven First layer Thickness, Growth Rate and Number of Layers, individual layer thickness and total thickness can be calculated as follows for inflation layers Nth Layer Thickness = (First Layer Thickness)* (g)^(N-1). Total thickness = (First layer Thickness)*[1-g^(N+1)]/(1-g) where g is the growth rate.
- Skewness in ANSYS Meshing
