How to calculate a fraction of surface area where a variable is less than a percentage of average variable?
June 6, 2022 at 8:32 am
FAQParticipantThe area fraction on a surface where a variable is less than a certain percentage of the average variable can be calculated with the following expressions. A report definition can then be created based on the uniformity expression to monitor the value during the run.
threshold = 0.1
avg = Average(StaticTemperature,[‘outlet’],Weight =’Area’)
areaoutlet = Area([‘outlet’])
uniformity = Sum(IF(abs(StaticTemperature-avg)/avg// php bbp_topic_pagination_count(); ?>
- Skewness in ANSYS Meshing
