Tagged: fluent, fluid-dynamics, General - FLUENT, N/A
March 17, 2023 at 8:59 am
FAQParticipantIf you have started a fluent simulation via the “Calculate” button in the Graphical user Interface (GUI), every time fluent saves files windows are popping up shortly. This disturbance can be avoided if you initiate the calculation via Test User Interface (TUI). Stationary: /solve/iterate 99 Transient: /solve/dual-time-iterate 99 20 where 99 is the number of physical time steps and 20 is the number of iterations per time step Keywords: fluent, windows popping-up, autosave, saving files
- Skewness in ANSYS Meshing
