June 6, 2022 at 10:32 am
FAQParticipantA smaller Gap Factor results in less layer compression and could help to avoid stair stepping. The Gap Factor can be changed under ‘Advanced Options’ for Inflation in the global mesh settings (click on Mesh, in the Details of Mesh, expand ‘Inflation’, set ‘View Advanced Options’ to Yes).
- ANSYS Fluent: Watertight Geometry Meshing Workflow
- Tip on exporting geometry in Parasolid, STEP format from DesignModeler
- Create Sections in Meshing
- How to reverse surface normal in SpaceClaim?
- ANSYS ICEM CFD: Basic Blocking
- How to Change the Direction of the Normal Vector of the Internal Face?
- ANSYS Workbench: Decomposition and Hex Meshing – Part I
- Fluent: Watertight Geometry Meshing Workflow
- How to Fix the Error: “Mesh Exporter does not Support Overlapping Geometry in Named Selections”?
- How can I create a 2D section from a 3D model in SpaceClaim ?
