How to avoid following error message? Error Message: Error at Node 17: get_time_inteprolated_value: profile “”” does not exist. “
Tagged: 19, BCs & Interfaces, fluent, fluid-dynamics, materials, rotating-machinery
April 5, 2023 at 2:32 pm
FAQParticipantIf you do not define cell zone rotation axis origin and direction correctly and try to run a journal file then this error comes. Please set rotation axis origin and direction to get rid of error.
- Skewness in ANSYS Meshing
