Modeling & Meshing
Modeling & Meshing
How to attach an STL file into Mechanical?
    • FAQFAQ
      Participant
      One cannot import an .STL file directly into Mechanical. However one can bring an STL file into Spaceclaim Direct Modeler, then attach that geometry in Mechanical. Generally .STL files are not able to capture geometry appropriately, but Spaceclaim can repair the .STL file, if needed.
