June 6, 2022 at 9:58 am
FAQParticipantFor assigning Local CS to set of elements, you can use EMODIF command. Please see the command snippet as following,
/PREP7
CMSEL,S,ELEM_SET,ELEM !!Select the required elemental component
EMODIF,ALL,ESYS,12!!Using EMODIF, modify all elements’ ESYS. Here Local CS is 12
ALLSEL,ALL
FINISH
/SOLU
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- ANSYS Mechanical: Node Move
- How can you identify the element types used by Mechanical?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
