January 25, 2023 at 7:34 am
FAQ
ParticipantAn easy way to apply initial stress to nodes would be to select the elements for given material id and then selecting the nodes associated with the selected elements and then using inistate for nodes.
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
- ANSYS Mechanical: Fatigue Crack Growth Analysis using SMART Crack Growth
