March 17, 2023 at 8:58 am
FAQParticipantWe can use the “Replace” option in from the ‘Groups’ panel. 1) Select the named selection 2) Ctrl select to add/remove things to/from this named selection 3) Right-click on the named selection and select “Replace” option We can also use the ‘Add’ or ‘Remove’ options to select only the objects to add or remove.
- Skewness in ANSYS Meshing
