Tagged: 16, fluent, fluid-dynamics, General, General - FLUENT
March 17, 2023 at 8:58 am
FAQParticipantThe identifier %f can be added to the end of the file name to include the flow time to the name while saving the case and/or data files. For example, issuing the following command in the TUI will add the flow time to the file names. >> file write-case test_%f.cas.gz
- Skewness in ANSYS Meshing
