March 17, 2023 at 8:58 am
FAQParticipantOn any of the views, if you RMB on the screen there is an option to “Copy to New Figure”. This will create Figure 1 that will show up in the tree outline under Report, but it will also be added to the list of views under the view pull-down menu.
- Skewness in ANSYS Meshing
