June 6, 2022 at 9:58 am
FAQParticipant1. Try reducing the angle between two parts before going for impact analysis – this helps in reducing the applied load.
2. Reduce the FKN value in the contact settings.
3. Use impact constraints for time step controls.
4. Increase the number of substeps.
