Heat Transfer
Heat Transfer
How to access to autosave-solar-data when the solar load model is active
    • FAQFAQ
      Participant
      The command is under: /define/models/radiation/solar-parameters However it is only available if we launch Fluent in parallel with 0 core. It is not available in serial or in parallel with 1 or more cores.
