April 5, 2023 at 2:32 pm
FAQ
ParticipantThe variables of the porous solid do start with the material name of the porous solid. So if the porous solid is “Steel”, then the temperature of the porous solid is named Steel.Temperature. In the Variables list in CFD-Post an extra directory can be found, which has the material name, i.e. Steel. Inside this directory a list of all variables of the porous solid can be found.
- Defining heat transfer coefficient (HTC)
- Simulating Battery Pack Cooling System Using Ansys Fluent
- Thermal Analysis of a Radiator Using Ansys Fluent
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- What is the difference between internal and external emissivity?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- How to use Thin Walls with Thermal boundary conditions?
- Where do I enter radiation properties such as emissivity/absorptivity, are there any recommended values for certain surfaces, and where do I find them?
