Heat Transfer
Heat Transfer
How to access the solid temperature in a porous domain?
    • FAQFAQ
      Participant
      The variables of the porous solid do start with the material name of the porous solid. So if the porous solid is “Steel”, then the temperature of the porous solid is named Steel.Temperature. In the Variables list in CFD-Post an extra directory can be found, which has the material name, i.e. Steel. Inside this directory a list of all variables of the porous solid can be found.
