April 13, 2023 at 7:33 am
Solution
ParticipantOne can use transient structural analysis and define the rigid bodies, there define initial velocity under Initial conditions.Please find attached an example.
1. 2057169.zip
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
- How can I understand Beam Probe results?
