June 6, 2022 at 8:33 am
FAQ
Participant1) for the face to face option while using the S2S radiation model in ANSYS Fluent, the number of faces per cluster needs to be defined as user input
2) the solver clubs these many number of elements on a surface and stores their weighted average value of view factors as the cluster view factor for radiation heat transfer calculations
3) these number of faces per cluster should be defined considering different parameters: a) the mesh resolution ( surface mesh elements ); lower the value for coarser mesh and vice versa b) the temperature gradient expected ( lower value for high gradients ) c) parts shape/geometry ( lower the value of complex shape parts, etc. )
- Defining heat transfer coefficient (HTC)
- Thermal Analysis of a Radiator Using Ansys Fluent
- Simulating Battery Pack Cooling System Using Ansys Fluent
- How to add comments to journal file so that I will know what each entry does?
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- What is the difference between internal and external emissivity?
