June 6, 2022 at 8:33 am
FAQParticipantThere is no limit in Forte to the number of species and reactions in the chemical mechanism. In general, Forte is designed to handle large chemical mechanisms. Typical mechanisms used in Forte can have up to 500 species. In some cases, larger mechanisms have been used. Adding more CPU’s to the parallel simulation will improve the turn around time.
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- How do I use the Flamelet Generated Model?
- How can volume fraction be plotted in a species transport simulation?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
