Tagged: 19, General, mechanical, static, structural-and-thermal, structural-mechanics
March 17, 2023 at 9:00 am
FAQParticipantFor quad shell elements (Shell 181) if the model is linear one then 3 integration points are used otherwise 5 integration points are used with plasticity. You can issue SLIST command via command object which will give you the details in Solver Output.
